you have to put gauges on it. no way that one can enough if system was low. the low pressure cut out switch is on the big line on the passenger side. you can test it by unplugging it and put a jumper wire in it, the plug. that will tell you if its just a fuse or still maybe low on charge
Romans 7-8 |
