Old 08-17-2012, 08:09 AM   #1
To the best of my knowledge to use a High Steer kit on a Toyota you have to have a drop hanger of at least 2-3 inches or have lift springs with a minimum of 4 inches and bump stopped in order to keep parts from binding. Does this answer your Question ?
Old 08-17-2012, 10:06 AM   #2
U don't need all that lift... Notch your core support and move box another 1/2-3/4" forward... Will fix your issues... And will not hurt the core support... I think rear springs move axle 3" so the box needs to go farther... Last one I did I had to notch core support and body mount but had just enough lift to clear 35s with some trimming... And he basically daily drives it
Old 08-17-2012, 10:37 AM   #3
fastford
Banned
Images: 13
if you get trail gears drop hanget you wont have to mess with core support or body mountd, and it doesnt give you much more lift. I used it on the 85 yota i had
Old 08-17-2012, 11:34 AM   #4
Jonesy
Jonesy's Avatar
It just has the factory packs right now. I am planning on adding a leaf or two in order to bring it up a little. I'll hack on the core support a little since that is free and I don't have to wait on a part to show up. I'll look at installing bump stops as well.
JT Jones
83 Toyota - beater
87 Toyota Truggy
