ran them on all four corners of my camaro to fit the ZR1 rims , all of them were 2" . I'm going to run them on the Jeep as soon as I find a good deal on a set.\
What axle are you looking at putting under your XJ that's 5 on 5.5 ? |
anywhere but there
most likely an 8.8
I beat anorexia!
ok ! most people use the 8.8 out of an explorer for a jeep swap ! 5 on 4.5 and 31 spline shafts.
I beat anorexia!
Yeah this one came from a bronco so it threw me off a little. but it is full width or darn close
are you going to run spacers on the front ? All of the coversion adapters that I have seen give you at least 1.25" width , these on a full width in the rear are going to be much wider then the D30 in the front . 3"-4" spacers on a D30 is going to put a heck of a lot of stress on your ball joints and unit bearings.
Think .. scrub radius!
