10-10-2012, 06:56 PM | #1 |
s10 wont start unless i use starting fluid
I just got a 93 s10 4 cly 5 speed for a real good price. It has new wires plugs fuel filter injector. It will not start on its own unless I spray starting fluid in it but then it will fire rite up and run all day. Once I shut it off I have to spray it to start it again. I was thinking fuel pump but I thought if the pump was bad it wouldn't run once I got it started. Any ideas?
real trucks dont have spark plugs |
10-17-2012, 01:59 PM | #3 |
Guest
Posts: n/a
my s10 did that... it was the fuel pressure regulator. i did the lines and the fuel pump and injections and mani fold gasket... and after all that it turned out to be the presure reg
10-17-2012, 02:54 PM | #4 |
X2 on the pressure reg. It is bad causing the pressure to bleed off when the truck is not running. It should start without starting fluid if you crank it long enough.
LIKE IT OR LEAVE IT!!! |
