Would it be ok to weld a cage with a 110v welder using external argon gas shield, or would you need a 220v machine to be safer?
I beat anorexia!
it will be using .120 tube
I beat anorexia!
sounds good, that is what I had planned on. Slow and steady wins the race. but In your opinion are we better off using gas and wire or flux wire for welding something that thick?
You get a better weld with gas than you do with flux.Gas is to keep the oxegen and impurities out of the weld.
The thickness would only matter with how many passes you make and how much care you take in preping the welding area.Which one of the most important part of the whle process of welding is your preping of the weld area. Shawn |
#7 | |
well go forbid someone mention it again...
Shawn you freaking idiot, can you please read every other thread before you post something that might have already been covered. Truggy doesnt have time to read thru all your repeating crap... Thanks for the input, i agree, prep is the most important part of any weld, no matter what kind of wire and gas you are using.
