Ready to Wheel!!!!!!!
Correction, it appears to be the wrong truck. Just noticed Krawler's sig pic..
Need updates,,,,
Goats on the Roof!
Goats on the Roof!
Are these worth it?
longfield has great rep. so i sure they are, and they cheaper then superjoints or nitros. they redid them also so only got 1 fitting instead 4 to grease.
SMITH BUILT PERIOD |
#5 | |
I have stock Dana joints in mine and have yet to break one. If I were to break one, I would probably go to a better joint. |
Goats on the Roof!
Well, I met up with Scott and Rob, and they are some good dudes. The red Jeep is badass too. Scott said the caliper brackets are done! Cant wait to pick them up. Instead of opening the bore on the bracket, he decided it would be better to turn down the spindle such that it'll fit nice'n'snug into the caliper bracket. So
![]() I do have a question though... Is this the right PN for a Detroit? 225SL29A I'm getting pretty close to finishing the bumper. After many grinding and checking attempts, I was finally able to get all the tubes to fit. They are currently just tack'd together. I need to add the inner 'webbing' pieces, so that'll be another 500x grind/check session. I'm sure using a hole saw+vise is easier, but this is the first time for me, so, so be it. Also, parts are rollin' in, hooray for tax time. I'm waiting on Ruffstuff heims. Next to purchase is a master rebuild kit from a friend in C-bus, gears, and the Detroit. 4wd factory has an April sale going on now too. I could get that thing for cheap right now. Well cheap in the 'offroad' world. ![]() ![]() ![]() ![]() Last edited by BillysGruff; 04-19-2013 at 09:07 AM. |
Goats on the Roof!
Bumper progress
