Old 06-28-2013, 01:58 PM   #1
dan
gotta love middletucky
dan's Avatar
the cps is new but from what i understand its a 50 50 shot getting one from autozone
98 xj 4.5" lift
Old 06-29-2013, 03:52 PM   #2
race4fn
what?where?whateva.....
race4fn's Avatar
Thats where I would start, mine was autozone cps and had to replace with jeep one..
race4fn is offline   Reply With Quote
Old 06-29-2013, 06:20 PM   #3
A bad CPS = no spark.If you have spark,than the CPS is good.I would try the starting fluid recommendation from Tom(Comanchedude).Also, a compression check,along with a spark plug check...
Good Luck
Old 07-09-2013, 06:01 PM   #4
Any progress?
Old 07-09-2013, 08:55 PM   #5
underpowered
They call me......Scuba
something to check is on OBDII Zj's, a loose connection at the PCM will cause them to shut off. check the PCM plug. unplug, clean, plug it back in.
if it truely does have spark, fuel, and is in time there is absolutely no reason it should not start at the minimum.
beat up rusted out k5
