Ex cab linked both ends makes for LONG wb... My buddies is 12 9 and be tough to get it much shorter and still have good approach/departure angles... Mind is 116" and right where I wanted it
- Moderator - |
Your engine, axles, frame size are what's killin you on weight, my rig weighs in at around 3500 Lbs, start downsizing on axles & motor, besides its your weight that will hold you back or brakes you in the first place. Just my opinion...
#3 | |
Yea ill measure tomoris mornin when I'm at my shop... Those are tons and 43s ...it will be fairly low for a truggy rig... 23" belly and 76" to top of cage...
Mine is over 5000, I am sure. Ext cab small truck, wheelbase=131. You have to ditch a lot of creature comforts and tools/parts to get the weight down. Good luck. A thousand pounds is tough.
That is my thoughts exactly!! more motor!
SMITH BUILT PERIOD |
#7 | ||
The stock 5.7 tbi with 155000 miles on it is tired. I definetly need a boost in HP. I found an all aluminum 5.3 take out motor for $1300 on Ebay. It has 325 HP. The 5.7 had 205 HP. This engine has to lighter than my all cast iron turd. |
They call me......Scuba
Cab buggy is best of both worlds.
having a large rig on tons and big tires but keeping it light is tough. i want to weigh my beast, i am betting about the same as your truck at about 5200lbs or so. it is wider than your truck though, slider to slider is 80", but belly is 24 with an 84" roof height. my next ride will be all tube, either with cab, or even just full side panels.
beat up rusted out k5 |
i like where this thread is going..just saying!
#10 | |
#11 | |
There are things I can do now to save weight. I know my stock doors are heavy. There's an easy 150 lbs. I just don't know if it's worth it to build a whole new rig to save 500 or so pounds. If you don't mind, could you throw a tape across your rock sliders and let me know what it is. If what I read online was correct, my cab is only 8" wider than the s-10. That doesn't sound right. Thanks |
