www.buckeyejeepers.com
Suggestions on Drivetrain swap
Looking for suggestions on rebuild of my YJ. I picked up an HPD44 with Ox and D60 with Detroit from Hardluck friend for a good price. I was planning on regearing and running a flipped D300 on my YJ, but got to thinking today about not regearing and running an atlas. I will be running 37-38 tires AX-15 and 4.0
ORIGINAL PLAN – Regear both axles to 5.13 and flip D300 - Gears and install kits ($550) ,D300 ($150), D300 Flip Kit ($550), Gear Installation ($200), Clocking ring ($100) = Total of $1550 for a Crawl ratio of 51:1 TODAYS CONTEMPLATIONS! – Leave axles at 4.10 and buy atlas 3.8 or 4.3 - Cost $2000, Crawl of 60:1. It would only cost me and addition $450 and would save a ton of time and hassle with re-gearing and flipping the D300. I know overdrive would never ever be used but how underpowered would I be when not in low range? How bad do you think taking off from a stop would be? This is not a daily driver, but I do want it to be driveable on the road at 55-65 mph Let me know what you think Thanks Josh
1994 YJ, 4.0, 5 speed. *2006 Dodge 2500 Cummins, 4x4 Auto,Quad cab, LongBed, Tekonsha Prodigy(Tow Rig) Last edited by JeepHD; 10-08-2007 at 03:18 PM. |
I know I can't answer your question posted above, but you're also gonna have to account for a few other expenses into either scenario. (driveshafts, axle perches/mounts, rims, etc) Are you planning a gas tank relocation & wheelbase stretch also? This kind of project can add up real quickly.
Atlas is looking good. Are you running stock 30 and 35 axles now? If so you may want to go with stronger axles but if not run the atlas or the stak and have front and rear dig capability and sell the 300.
#4 | |
Stak4x4 monstor boxes are also an option that I am looking into. Thanks for the response
#5 | |
Just started checking on the Stak boxes. I will be comparing them with the atlas. Thanks for the input
go with the Tcase gearing. not only will it be easier, but stronger as well (depending on if you upgrade gears on the 300 or not.)
go with the stak, but im biased, and havent even run mine yet.
#7 | |
Thanks
I went through them directly for quick service. Carwash knows em pretty well too!
Well I am leaning toward a Stak or Atlas and leaving the axle gearing at 4.10 for now. I know it will be pretty weak on power in road gear for now but I can always change the axles down the road sometime. Should I go with the 3.8 or 4.3 gearing in the t-case?
4.3 or the 3 speed stak and have multiple ranges! 3.73 or 4.10 ratio is said to be the strongest for a 44 or 60. Pinion still has some girth!
What did your 3-speed stak run you? I probably stick with the two speed due to cost
#13 | |
That's just the thing. Budget is not going to accomodate both the case and gearing. It's either gear the axles and flip the case, or leave the axles alone and get the low geared atlas or stak. Thanks
$2900 with options and shipping last year.
#15 |
Thanks, I will be staying with the two speed.
#17 |
Thanks, I will probably go with the T-case. Maybe gear swap next winter
#19 | |
Are you a vendor for them or can you get any discounts from them. I will be going with a 2 speed. Thanks
#20 |
When is the delivery of the stak and what ratio did you go with?
#21 | |
From what I read on pirate, there will be a price increase in November.
#22 |
Check on stak4x4.com for info. They offer 1350 yokes standard and flanged and 1410 and others as an option. The parking brake option is awesome! You are going to love it.
#23 | |
Anyone around make good custom driveshafts at a reasonable price?
#24 |
Driveshafts at a reasonable price? No one around here that I know of. If you want to spend a fortune go to power clutch and drive. They make gold ones! :(
#25 |
