u-joint question
I'm replacing the front axle u joints in my xj.
In the past, I've never been a fan of greaseable, but that's always been in my trucks that never got that dirty. Crossing creeks and stuff in my xj has me wondering if I should use the greaseable style. Any opinions? |
IMO, greasable joints are weaker than non-greasable because they are drilled so the grease can get to the caps/roller bearings.
LIKE IT OR LEAVE IT!!! |
Not just his opinion, that's a fact.
Sealed (non greasable) is the way to go. Robert
Non-greasable (solid) u-joints are stronger than greasable (drilled), but it is a very, very small amount (assuming all else is equal). When you drill the small grease channel in the middle of the round cross-sectional area you simply don't decrease the strength of the part that much. Same calculations for determining the strength of tubing. If you have 1" tubing and go from .125" wall to .250" wall you have doubled the wall thickness (increase by 100%), however the strength only increased by around 35%. In the u-joint the equivalent wall thickness between a greasable and non-greasable is probably only around 15% different which would equate to maybe a 5% difference in strength. 5% is 5% but in the real world if you broke a greasable u-joint on the trail there is a good chance you would have broken the non-greasable version in the same situation.
Thanks for the input. I'm going to get non greaseables.
I'd go greasable and put a shot of grease in them everytime you go on a ride. The joint is more likely to fail from contamination than the slight decrease in crossectional strength.
Ian 06 Toyota 4Runner |
Makes sense to me with a near stock driveline.
- Moderator - |
I totally agree
Non grease able for sure ... They r stronger ... And who in the heck actually greases u joints on regular basis anyways? Lol
#10 | |
- Moderator - |
But I agree not many people look over their rigs... Lol
I'll buy one of each.
#12 | |
I like that idea. beat it to death with whatever maintenance you care to do and report back on the results. I personally cant speak on the true structure of each but I have had a greasable on give up on me and eat the ears on one of my front axles so I switched to non and been good for a while. just my experience
One of these days Zuk 2.0 |
#14 | |
#15 | |
#16 |
SeƱor Monkey
Bahaha!
#17 |
Get real Spicers not parts store brands. If your XJ has the big U-joints get 760x they are significantly stronger than 297s or whatever that parts stores will try and sell you.
you can get the spicer 760x's from rock auto for about the same price as parts store brands. Jim |
#18 | |
#19 |
I busted 3 of 4 of the caps in the first one so out of frustration I'm going to pay for the first time to have them done. B&T in Milford will use Spicer.
