Old 11-25-2013, 12:47 PM   #1
Longfield or Nitro. Longfield is the best ImO
Old 11-25-2013, 01:28 PM   #2
rcv makes them all including trailgears dirty thirtys
Old 11-25-2013, 02:34 PM   #3
You can't go wrong with Dirty 30's. Just keep in mind the hub gears will be the next weak link, if a hub gear fails it can wipe out the splines on the hub end. Do it right and break down and get Chromoly inner & outer hub gears along with ARP Hub studs. Then the worries are over..... Unless you break the R&P... Lol...
Old 11-25-2013, 05:02 PM   #4
tjeep
Right now I'm running trail gear r&p Yukon Cromo shafts inner and outer with super joints trail gear crawler hubs and trail gear crawler hub flanges ohh and a Aussie locker....... I just didn't know if the birfield type joint was better that a u joint type.... The longfields look way stronger that the super joint IMO
tjeep is offline   Reply With Quote
Old 11-25-2013, 06:30 PM   #5
People have been beating on Longfields for years in Yotas... It would be the only stuff i would buy...
Old 11-25-2013, 06:55 PM   #6
cv axle stronger at lock cause dont bind like u-joints, id go spool instead locker though if not a driver, lockers fail if beat on hard every trip, but last long time for average trail rider
Old 11-26-2013, 08:15 AM   #7
..... Untilyou break the R&P... Lol...
Fixed it for you.
When the unjoints fail, they tend to take the knuckle ball with them. I have asset for spares only bc they came in mine when I bought them. Sucks to replace the knuckle ball. I've done it once on mine (hence the reason they are now my spares). Can't go wrong with longs.
Old 11-26-2013, 08:37 AM   #8
30 spline longs with driveflsnges and don't look back
Old 11-27-2013, 07:12 AM   #9
I purchased a set of Longfields back in 2011,still holding up to my abuse.
Old 11-27-2013, 01:03 PM   #10
Nuts's Avatar
Sell the yota axles and take whatever you get for them and whatever you were gonna dump into them and buy a set of 1 tons. Building yotas is just putting off the inevitable and wasting time and money.
