I know that people on the wildcat forum go there and wildcats are wider than 50
I would be willing to guess that they are not measuring every vehicle that goes through. If you are obviously over you will get stopped but if you are close you should not have a problem.
They dont measure anything...they build bridges at 51" wide and if can't fit you can't ride..
That's within 6" of a stock XJ/YJ/TJ/ZJ...
The XP1K is 70" wide. It will fit in the 50" areas if you go really quickly. There is talk about extending the width of the state trails to keep up with the new machines.
#8 | |
They also usually have gates at the trailhead that wide also. I'm sure the original intent was so only ATVs could use the trails, which was before the explosion in the SxS market.
