There are different kits to accommodate either the electronic or mechanical speedo. The 231 in the picture is setup for the electronic and you say your Jeep is setup for a mechanical speedo. As said above with the correct kit the original speed sensor or speedo housing will just bolt in to the new SYE housing, but obviously you can't do that. Not really sure what you would need to do to convert, but one option is just to buy a cheapo GPS and mount it on the dash!
I have the JB conversion super short sye. It converts the speedo gear to an electronic sensor. Comes with the kit. Its a very common set up. Check them out
SeƱor Monkey
I've not seen the super short versions,.. does he just need the correct plug adapter or something to connect to the Jeep wires?
