if ur 39.5s aint wore out buy good groover and put aetna cut on'm so you get to that hook dirt sense it gets trailerd
SMITH BUILT PERIOD |
#2 | |
I found a place that shows the LTB's are backordered till mid April. http://interco.factoryoutletstore.co...8,80633&page=1 I was doing some measuring to see if I could fit 42's up front, and the leaf springs pins aren't centered. They are offset about 3". If I flipped them around I could probably fit 42's in. That would give me a 120" wheelbase, which I really don't want. So I'm back to 40's. An 18" bogger in the rear is freakishly large to me. Sure wish they were 15" like the TSL. It looks like I either go down to a 38.5 SX, stay the 39.5 TSL, or use the 40" LTB. I would like to know why Interco's tire sizes are all over the place... ![]() |
if you can make the 42's fit I would run those. I have a buddy that went form 38's to 42 and it makes a lot of difference on how well you can get around.
I could fit a TSL SX - 15/42-15LT in easy enough. It's only 41.5" tall. One of the things that worry me about 42's on 15" rims is all that side wall showing. I'll get more tire flex, but wouldn't it make them more susceptible to slicing? According to that website, they would be available mid March.
#5 | |
They call me......Scuba
it would only be roughly 1 more inch of sidewall over your current 39.5's. you already have a bunch of sidewall.
42's will be my next tire after the 38.5's.
beat up rusted out k5 |
If I get creative, I could make 42's fit without moving the axle forward. I could notch the firewall some more and do something with the cab mount. This sounds like a plan.
