PM sent...
Im looking for doors five 13 four o5 2220
Have a buddy in tenn. says he will give you 500.00 for it right now
Boom: I got your message..he should be approved now.
PM sent.
#12 |
frame
Are you willing to sell just the frame? Is it in good condition?
#13 |
before you go parting it out, sell it to my buddy tnranger so he can build his soon to be wife a rig. we need more chicks that like to wheel the hardest stuff out there.
there has to be something said about a good looking girl driving a built rig. that is just downright sexxxxxy right there!
#15 |
Axles
What ratio are the axles? if 4.10 how much. my 3.09 dont like 35's on the sreet?
If your not living on the edge, your taking up too much room. |
#17 |
$900.00 for the tub, frame, title, doors, hood, cowl and ?
#18 |
Jeep
Is the frame straight or has it been hit?
Four or six frame? What is available? Thanks,Teach |
#20 |
Icemanjes
Is the frame straight or has it been hit? As far as I know it has never been hit.
Four or six frame? Not sure will have to check on what you mean about 4 or 6. What is available? Everything that is in the pictures.
#21 |
The motor mounts were different for a 4cyl vs a 6cyl, but I personally can't ID one from the other by sight...
Good luck with it! Robert
