#32 |
- Moderator - |
Pretty good day at Haspin today, pretty sure it would be Brad that had the most carnage/ issues today, First it was a broke center pin on the front driverside with bottom leaf spring falling out (which we looked for and never found), then his shackle bolt for the passenger fell out somewhere leaving his front axle wanting to go where ever it wanted to go, he was lucky and able to drive it to the fire road only too loose all the air in his rear driverside tire, we decided to go and get truck and Trailer to load it up, Jeff would come in second with a few tire issues and to end his run would be a cracked and bent track bar mount on the axle housing. Driving a razor for the day was a learning experience more than what I thought it would be, would really take alot of time to get used to it and know what it is capable of. Will post up some picks
