Old 07-29-2015, 12:51 PM   #1
The pcm will shift out of manual 1st to 2nd at the WOT setting specified in the tables. You can start in 2nd, but if stomp on it it will kick into 1st. The easiest way to solve this is to use a shift kit. http://www.summitracing.com/parts/tr...-hd2/overview/ It is exactly what I want. The last kit I did I set the shift firmness to towing so it didn't snap hard. It was fine in 2 hi, but 4 lo was was harsh at higher rpms. I might leave the firmness stock and have the firmness adjusted in the pcm. I do think hooking up the 4 lo wire will help with shifting in drive, but that's it. For now, I will hook the 4 lo wire up and deal with it. I just changed the fluid and flushed it out with Dex 6, so I'm thinking this winter I'll do something. That was like $100 in trans fluid...
Old 07-30-2015, 12:45 PM   #2
The wire I should've left intact. DOH!!!
Old 08-10-2015, 07:00 PM   #3
I pulled the harness mostly back out so I could run the 4 lo wire and see what the deal was with the MAF sensor. I was thinking that I attached one to many black/white ground wires together. GM uses black and black/white wires for sensor wires too, not just grounds. Well, that wasn't the problem, they were all good. When I shortened the harness, I staggered the solder connections so there wasn't any next to each other and used shrink tube. For whatever reason, I didn't stagger the MAF wires. Well the shrink tube shrank too far, and a few pointy soldered wires were sticking out and touching the other wire. I fixed those and now the IAT reads within 2 degrees of the coolant temp, or room temp... I'll know tomorrow how the 4 lo wire works out.
Old 08-11-2015, 09:33 AM   #4
tbshakie
that has to be frustrating as hell. I am glad that you are making progress.
1976 CJ 5
1984 CJ 7
1993 K3500 GMC 6.5 TD
Old 08-11-2015, 12:37 PM   #5
Yes, very Hopefully it will run like it should now.
Anyone ever run Tom woods off set u-joints? Curious to see how they hold up.
My front t-case joint binds some at full droop, so I bought one hoping it won't bind anymore. I usually have to service that joint after every ride.
ATTACH]8381[/ATTACH]
Old 08-11-2015, 01:06 PM   #6
tbshakie
I don't know anyone that runs them. Have read they vibrate like hell at anything over crawling speed, but I do NOT have any first hand experience.
1976 CJ 5
1984 CJ 7
Old 08-11-2015, 08:11 PM   #7
My front shaft is made with AG spline, so I'm sure I won't notice any extra vibrations.
Old 08-12-2015, 07:26 AM   #8
Out of curiosity, did you now have the VSS on the transfer case or transmission? Glad to hear it is running better now. Now it's time to tear it back out for a cam and a shift kit!
Old 08-12-2015, 08:36 AM   #9
It's on the tcase now. There may be a cam in the future, but I'm done for a while...
