- Moderator - |
I put the factory toyota A/C compressor back in 2004 and have used and abused it, pressure switch kicks compressor on at 110 and turns it off at 150, it has saved my butt and others over the years. I just put a little compressor oil in it a few times a year and it's good to go. With the tank and components I believe I have less than $100.00 in it.
Update, the whole system seems to bleed off almost exactly 1psi per hour. I am totally okay with that.
I'm gonna blame the HF hose reel. I could put a block valve before it to verify, and if it gets worse I might. But running the compressor 2-3 minutes every 2-3 days is perfectly fine with me...
Update II
Used the hell out of it on the Tour this weekend. Worked great. Will fill a tire in no time, and will definitely run my impact. One slight snafu: Wiring it off the battery was a mistake. If I shut off the engine before the tank has pumped up, the solenoid on the clutch stays energized. This will (did!) drain the battery in just a couple hours. I'll rewire it through an ignition switched source, and it should be good to go. Otherwise, I'm happy as a clam.
I had a little viair, but it was awful loud, and wouldn't even keep up filling tires at the end of the day.
At 2000 rpm, this one will flow 8cfm at 150psi.
