Old 10-22-2015, 07:11 PM   #1
Update, the whole system seems to bleed off almost exactly 1psi per hour. I am totally okay with that.
I'm gonna blame the HF hose reel. I could put a block valve before it to verify, and if it gets worse I might. But running the compressor 2-3 minutes every 2-3 days is perfectly fine with me...
Old 10-28-2015, 10:12 PM   #2
Update II
Used the hell out of it on the Tour this weekend. Worked great. Will fill a tire in no time, and will definitely run my impact.
One slight snafu: Wiring it off the battery was a mistake. If I shut off the engine before the tank has pumped up, the solenoid on the clutch stays energized. This will (did!) drain the battery in just a couple hours.
I'll rewire it through an ignition switched source, and it should be good to go.
Otherwise, I'm happy as a clam.
Old 11-01-2015, 08:36 PM   #3
I installed a Dual Viar system on my jeep. I love it and it works great!.
Old 11-03-2015, 10:04 PM   #4
I had a little viair, but it was awful loud, and wouldn't even keep up filling tires at the end of the day.
At 2000 rpm, this one will flow 8cfm at 150psi.
