Old 11-11-2015, 08:02 AM   #15
I have a good paper filter in my reservoir, will have to check it for metal. When you changed pumps, was there a lot of metal on the magnet? I haven't seen any major metal on mine.
Very little metal on the magnets but thats because the piston inside the ram was aluminum. The cylinder walls were scored which in turn started chewing up the piston sending small aluminum particles throughout the system. I ended up replacing the ram and all the lines along with putting a 5 micron filter in the return line. I probably didn't have to replace the lines but didn't want to chance ruining my new KRC pump and ram.
