Truggy LS 6.0 / TH350 / Atlas 3.8
EXTERIOR
2005 Colorado/Canyon extended cab 1 3/4 .120 DOM on cage, .188 on lower frame rail and impact areas 4 linked front and rear on Fox air shocks 1 1/4 heims on lowers and 3/4 heims on uppers DRIVETRAIN 2006 LS 6.0 Built th350 - TCI internals, full rev manual valve body, art carr shifter, JEGS converter and cooler Atlas II case - 3.8:1 HD outputs 1350 yokes .188 chromo driveshafts - Carolina Driveline AXLES Chevy Dana 60 front Yukon chromo axles 5.38 gears Yukon grizzly locker undercover fab diff cover 14 bolt rear w/ disc brakes 5.38 gears welded carrier undercover fab shaved diff cover STEERING PSC 2.5 x 8 SE ram PSC GM pump PSC reservoir Charlynn Eaton 185cc/11.3ci orbital 5x11 cooler with fan OTHERS TWF double beadlocks w/ inner and outer reinforcement rings 43" Super Swamper SX's with AETNA cut - 90% tread 31x19 Northern aluminum radiator RCI aluminum fuel cell TWF 20" lightbar I have tons of spare parts including axles, an extra shock, spare driveshafts, etc. Asking $28,000 OBO Call/text 513-460-1806 Located in Cincinnati, OH http://www.hardlinecrawlers.com/foru...9349#msg419349 |
