02-11-2016, 11:08 PM | #1 |
Señor Monkey
Willys Truck Build
I figured I'd go ahead and start a build thread for my Willys truck project.
The guts of my project is basically a K5 Blazer chassis. 350 tbi, 700r4, np241, D60, 14 bolt. My 47' cab. I'll post more as I make progress. So far it's been a real blast to build. (Pulled the k5 body with a small harbor freight engine hoist :) ) Sent from my SM-N900V using Tapatalk |
02-12-2016, 03:21 PM | #2 |
Gonna look good. I love the old Willys trucks. The cab is an older model with the small rear window.('48-53?), but the hood and grill is from '50 to '55. Probably '50-'51, unless someone added or subtracted some horizontal bars. I think '53 on up only had 3 bars, and in '56 the middle bar was above center line. '57 on up had an air intake opening on passenger side of grill with 3 equally spaced bars. Mine is a '59.
02-12-2016, 07:56 PM | #3 | |
Señor Monkey
The I have two cabs. I first bought the newer cab with the large back window and later found the small window cab. I like the small window better so that's what I decided to go with. The grill is newer but I think someone added bars or moved bars (at least that's what they told me on the willys forum) Sent from my SM-N900V using Tapatalk |
02-12-2016, 09:15 PM | #4 |
I think you should put it on 53 inch michelins
02-18-2016, 07:45 PM | #6 |
Señor Monkey
After all the shock talk at the meeting I'm thinking about linking the rear of my truck.
02-18-2016, 08:16 PM | #7 | |
Señor Monkey
This whole project has been a great learning experience. I definitely welcome any input or knowledge guys can pass on to me. |
02-18-2016, 08:41 PM | #8 | |
02-18-2016, 10:02 PM | #9 |
Looks awesome. Keep the updates coming !
Sent from my SAMSUNG-SGH-I257 using Tapatalk |
02-20-2016, 02:39 PM | #10 |
Señor Monkey
Body mounts are finished now.
Now I need to remove and replace the transmission and rebuild the np241 with a sye. Sent from my SM-N900V using Tapatalk |
05-16-2016, 10:52 PM | #11 |
Señor Monkey
-I finished the sye reinstalled the t-case and installed an indexing ring to clock the case upwards. It's going to be pretty close to a flat skid plate.
- I've completed the passenger side body work/ floor/ rust repair. The list of things to do is shrinking. I'll post up some photos later. |
05-19-2016, 04:01 PM | #12 |
05-20-2016, 10:33 PM | #13 |
Señor Monkey
Passenger floor finished.
