Old 01-18-2017, 06:33 PM   #1
Cage is .120 wall in critical areas and .090 in remaining areas. Gussets double as grab handles and anchor points. Tied into bumpers as well as the front and rear frame. This will improve the factory cage structure and integrity by more than double.
One big dilemma is weather or not to build the front diff before it blows. It will be easier to get to with the winch out. This entails a stronger billet bearing cage from 7075 grade aluminum, roll pin upgraded from .093 to .125 hardened dowel, hardened toner ring and spring tuned. Not sure yet.
Build the diff now. With that much power and bigger tires, it will die. Plus, I've seen the way you drive.
Old 03-13-2017, 12:37 PM   #2
Is it done?
