If anyone is interested, I have a good friend the sell 25watt waterproof dual bands and 75 watt dual bands. If interested, look up Brad Blair on facebook and he can hook you up for a lot less than rugged ridge.
- Moderator - |
I can't even begin to describe how happy I was with the trail communication, the stress level was completely gone knowing you had direct contact at all times and little to no possibility of someone falling behind, This communication needs to be the top of the priority list on wheeling outings.
Okay, you've convinced me that it's time I get something together. I don't want or need fancy, just functional.
So in my amazon shopping cart, I've got: - That Uniden pro520xl radio that Mark recommended as "the upper end of cheap." That's me. - A three foot, tip-adjustable Firestik, FS-3BK, per the "choosing the best antenna" link. - 18' coax, a Firestik HD stainless spring, and both their K4 and K4A mounting studs. Anything I should change before I pull the trigger? I may soften to the medium spring, it won't be on there day-to-day to be a problem on the highway. Once I pull my fender off, I can see what kind of bracket I'll want to rig up to reuse the factory antenna hole. My goal there is to protect the mount and base from damage, and just have the spring and antenna exposed. I may need to (may go ahead and) add a grounding wire, rather than trust the stud-bracket-fender-body connections. I guess since the coax ends at the stud, the spring itself is "live" and needs to not ground out on the fender. That'll take some attention. That radio will support an external speaker, but that's easy enough to add later that I'll try it as-is first. If I make it to Rich's could I get some help tuning it before Rush?
#7 | ||
It'll mount and ground through the 1/2" hole in the bracket I put inside the fender, then the spring and antenna will just poke up through the 1" hole in the fender.
Unless the spring leans over and contacts the metal of the fender, the edge of that 1" hole, that's my worry. Though, as along as it's not the moment I'm transmitting, I guess it won't hurt anything. Quote:
https://www.amazon.com/dp/B001JT0CGI..._MTZnzbDZVMMRP Quote:
Appreciate the advice, as always!
Whatever doesn't kill you makes you stranger Last edited by WrenchMonkey; 06-06-2017 at 07:59 PM. |
