Old 09-10-2018, 11:43 PM   #1
Zach’s buggy build
Started designing the new buggy for Zach. Upgraded my Bendtech to Pro today!
Old 09-12-2018, 08:06 AM   #2
I wish I could've used that on my exo. Not knowing the angles would be an issue.
Old 09-12-2018, 02:51 PM   #3
Looking good. Is the red salvaged CJ frame?....If so, id think about starting with fresh tube! Just my .02
Old 09-12-2018, 04:53 PM   #4
Nope! It's the new box frame we are making. The old CJ7 frame was cracked and rusting out.
Old 09-13-2018, 08:57 AM   #5
Good call, look forward to seeing progress
Old 09-13-2018, 12:58 PM   #6
Update on Chassis
Picked up ALL the steel today from Industrial Tube and Steel. highly recommend them. I called 2 other steel places and tubing is over $7 per foot for 1.75x120 wall. They sold it to me for $3.67!
Brody is bringing me I-Beams for a Jig I am going to build for frames and then we will be off to the races!
Old 09-13-2018, 04:23 PM   #7
Simply to be different
Old 09-18-2018, 10:53 AM   #8
barnhartal
If your planning on a future rear seat, push those s curves back as far as rear upper link clearance will allow. Mine has similar curves and when I put rear floor in for kids it kind of screwed them for footwell. Livable but not great.
Old 09-27-2018, 08:00 AM   #9
That may be an adjustment we make once we get started on the rear section of the chassis.
Old 09-26-2018, 03:20 PM   #10
New clear ORI’s are in and they are sharp!!
Old 09-26-2018, 09:31 PM   #11
So Shiny
Old 09-27-2018, 08:01 AM   #12
So Shiny
Oh I know! They'll look sharp on the jeep-buggy.
Old 10-01-2018, 11:13 AM   #13
Old Jeep frame is gone.. it’s been a great ride, but onto better things! Only thing that’s left to sell if the fiberglass tub!
Old 10-17-2018, 11:06 AM   #14
The people that were at Harlan convinced me to go automatic.. so I ended up getting a TH400. Now looking for an LS because why not upgrade right?!?
Old 10-17-2018, 08:11 PM   #15
You will not regret going to an automatic. Now all you got to do is point and shoot.
Old 10-25-2018, 03:30 PM   #16
Oh major upgrade here! ATLAS T CASE!
She’s a little old. From what we are told it’s never been installed. Atlas is either a late 90’s model or early 2000’s
Old 10-26-2018, 08:23 AM   #17
Is that a 3.8:1 low range version (looks like a 3.8 written on it)? Should work pretty good with the TH400. I was thinking originally that if you went with the TH400 but kept the NP205 you may not be happy because that combo gives pretty crappy low range ratio.
Old 10-26-2018, 10:14 AM   #18
That it is! Very pumped because of the stress I was going through in buying the adapter. Then buying more parts to either do the doubler or the gear box. So my dad made a very good point.. instead of paying $1500 for either the doubler/gear box why not just try to find a Atlas for only $300-500 more. But yeah this solves all my problems with finding a better gear ratio. Paid $1800 for it. So it's a steal because that includes the twin sticks, the TH400 adapter, and possibly a shifter for the TH400 instead of buying a Winters shifter.
My dad is going down to get it this Sunday since it's located in Georgia and he's traveling to New Orleans for work. He is also buying another TH400 with a reverse valve body. So we have an extra TH400 in the garage now that needs to be sold. Plus I'm selling my old 205 and the 203 I just got.
Old 10-27-2018, 08:29 PM   #19
Decent amount of progress made today! Got both axles put together (4links and 14 bolt gears). We also made the base of the frame, thanks to my dad Jeffrey Smith and his skills with the plasma cutter!
Old 11-05-2018, 10:05 AM   #20
Some goodies arrived today. Got my brake pedals and brake master cylinders. This allows me to have independent brakes!
Old 11-05-2018, 06:35 PM   #21
And some more goodies! TH400 shifter and the twin sticks for the Atlas
Old 11-08-2018, 08:42 PM   #22
While I’ve been doing college essays all week (stupid last semester) my dad decided to work on the frame. He got a lot done! Looks very good!
Old 11-11-2018, 05:54 PM   #23
Finally starting to see the bigger picture now. Pretty much got the frame done. Just need to weld it up and figure out how to do the upper front 4 links. Deciding whether to use the old 4 link brackets I have or cut into the frame and box it like my dads is.
Old 11-12-2018, 03:55 PM   #24
Lookin good.
Old 11-22-2018, 03:13 PM   #25
Buggy Build 2.0! We had to totally redesign the tube chassis today, since my dad switched computers and lost the original copy... But this design is similar with some adjustments. Overall width of the chassis is 67” (nerf bar to nerf bar) overall height is 42”. Total weight so far from Bend Tech, 470lbs. Can length is 59” wide to fit a Jeep cowl, and my original hood.
