11-19-2007, 06:02 PM | #1 |
Carnage from Haspin 11/18
Here is the damage to the 3rd member, and right side axle is shot.
I can not get the birfields out...grrrrrrr http://s188.photobucket.com/albums/z...t=IMG00200.flv folders of pics http://s188.photobucket.com/albums/z...damaged%203rd/ Looking for a right side axle and birfeild also!!
Thanks, 67fastback ------------- 84 Honda cr60r - for sale 87 Honda 200sx - for sale 67 Mustang fastback - under restoration MCA #63430 04 Silverado 2500 crew cab 87 sami - "SPLAT" 87 sami tin top - "Blue Fire" 88 sami - "Squirt" My New Video Channel -http://www.youtube.com/PhillbillyProduction My Video Channel - http://www.youtube.com/justworkn |
11-19-2007, 07:01 PM | #2 |
Yeah they do look a bit loose! Weld them up and go!
11-19-2007, 08:46 PM | #3 |
Pinion bearing explode? Or did you break the pinion gear itself?
11-20-2007, 07:46 AM | #4 |
I was looking at your pic. Did you try to pull the axle out with that bolt and chain?
Why did you not just pull the knuckle off and the axle would of come out the back side then? |
11-20-2007, 08:36 AM | #5 |
11-20-2007, 08:01 PM | #6 | |
well I tried everything to get it out, turns out that the someone put after market birfield rings on it so it would not slide out. so we had to take off the nuckle. here is the damage well the 3rd inside looked like this it should have looked more like this and the right axle
11-20-2007, 08:09 PM | #7 |
Good break! If you are breaking it you best go big! Sounds more impressive when steel snaps! Looks like you will have it fixed soon! Come on down to slade (red river gorge) this weekend with the gang.
11-20-2007, 08:12 PM | #8 | |
bearing blew out and it chewed up the gears too inside the housing and blew out the birfield and axle shaft was chewed up too on the right side! I need a right side axle for the front any one got one call me! asap! need to get up and going for this weekend! well the 3rd inside looked like this it should have looked more like this and the right axle
