This guy just cut his runflats, maybe you can get ideas here:
http://www.mv4w.com/modules.php?name...iewtopic&t=202 |
Let's burn 'em!!
I'm sure someone will have a campfire in the next few months, let's see how well these things burn! Do you remember playing with magnesium ribbon in Chet's class? That crap burns BRIGHT!!!
BiggDaddy |
#3 | |
www.buckeyejeepers.com
Maybe you should spend more time getting that grey goose flying again instead of playing on the internet, so that you can "try" to follow me on the trails this spring! ![]()
#4 | |
Later
I need some hummer rims. I will machine off the runflats for you for a good deal on some rims!
#6 | |
So what is the new build going to be? Going to us the truggy and just make some changes? Have you guys put together any kind of schedule of trail rides for 08'
Our 08 schedule will be decided tonight at the officers meeting. The rubber runflats are better? Are they lighter? If you know where I can get some rims let me know.
I am sure they would be heavier? Truggy on a diet? On the rubber, it just won't damage the tire when running low PSI or when tire is pinched against it? Also the outer rim of the rim is supposed to be stronger than that of the 8-bolts.
The 12 bolt rims are made for military use of a higher psi. rated tire and where a heavier load carrying capacity is needed. (I have been told) The less mass you are rotating the better. The more you can position weight where you need it the better.
#10 | |
#11 | |
Thanks for all the help. Worked out great
