Old 10-03-2007, 03:07 PM   #1
Question Welding basics
For those that have a welder but no idea how to use it, how do you start? Where do you set the dials?
Any other info is always appreciated.
:confused:
Old 10-03-2007, 04:30 PM   #2
What kind of welder?
mig
stick
tig
Old 10-03-2007, 05:01 PM   #3
I set it all over the place and tried it with different materials/rods. After I found what worked best that's how I (try to) set it.
Old 10-03-2007, 05:02 PM   #4
JET455
JET455's Avatar
Burn it till it holds!!!
JK
You need to practice and get used to the welder try different settings etc..
Old 10-03-2007, 06:28 PM   #5
fredrader
fredrader's Avatar
Here is the way mine were set last time I used them..The AirCo is a 230Amp Arc welder and the Lincoln is the 175Amp Mig..Both are 230volt machines..
Click on the pic for a larger view..
Miamisburg,Ohio. Cell# 937-361-7267
90XJ Limited 4x4,4.0 Auto,NP242
Rustys 4.5" lift D30/D35,3.55 gears
Denman Farmhand Tractor Tires 33x9.50x16
Work in progress
http://smg.photobucket.com/albums/v2...0XJ%20Limited/
1986 Chevy M1008 4x4 CUCV 5/4 Ton Truck
350ci,400turbo,D60 Front,14Bolt w/Detroit Rear
4.56 Gears, Desert Tan C.A.R.C. Paint.
http://smg.photobucket.com/albums/v2...0M1008%20CUCV/
fredrader is offline   Reply With Quote
Old 10-03-2007, 11:12 PM   #6
Well right now I have a 110 clark mig with flux core but no idea where to start.
Old 10-04-2007, 06:31 AM   #7
Get you a bunch of 1/8-1/4 inch plate , clean and prep your area to be welded and start making some test pieces. Learn what each power/wire speed setting does to the "look" of the weld , learn how important gun angle and position is as well as direction.
Old 10-04-2007, 05:44 PM   #8
Never weld with your battery connected :( in your vehicle and you may want to disconnect the computer too:o
Old 10-04-2007, 09:14 PM   #9
Here is a good bb for welding questions and projects.
http://www.hobartwelders.com/weldtalk/index.php
Old 10-05-2007, 02:56 PM   #10
Never weld with your battery connected in your vehicle and you may want to disconnect the computer too
Just recently we used my Jeep and several batteries to weld on the trail with some jumper cables and we didnt have any issues.
Old 10-05-2007, 04:44 PM   #11
I know you've had problems (that was you tha thad to get a whole new harness, right?) but I have been welding on my & my buddys Jeeps for a while now w/o disconnecting anything. I just make sure I got a good ground very close to where I'm welding.
Old 10-05-2007, 04:51 PM   #12
999 time out of 1000 you won't have any issue, but that 1 in the 1000 is a costly one. There is a reason that the first line of any repair in any haynes manual starts with "disconnect the positive cable of the batter."
Old 10-06-2007, 05:12 AM   #13
I thought of this thread yesterday at work after I saw the mechanic welding something while it was sitting on the back of his truck.
Just wondering if the welder sitting on the truck made a difference or not. I have a battery shut off so I try to turn it off when I weld on mine. I have stuck an arc on it without the battery disconected, but would rather be safe than sorry.
Old 10-06-2007, 08:38 AM   #14
if you are trying to mig weld;
you should try to push the puddle
-better looking weld is the main reason,
-most people push for sheetmetal,pull for plate steel
-it is easier to control,
-see your work while welding is better in my opinion
and if you ever go and try to get a mig welding job
and you pull the puddle, well you won't get the job
unless it is flux core wire
decent article below
http://www.customrodder.com/tech/060...ger/index.html
Old 10-06-2007, 08:47 AM   #15
looks like this video mite help
i had the volume turned down
not sure what he said
he has other video's
http://www.expertvillage.com/videos/...-lap-joint.htm
