Old 04-03-2013, 05:59 PM   #1
v8-yj
Chevy NV-4500 Transmission
I have for sale a chevy nv-4500 transmission 2wd but could be adapted. Advance Adaptors makes a kit to go to a D-300 or Np-231. Has the desirable 6.34 first gear as this is a 93-94 yr trans after that they are 5.61 first gear. Bought from a running truck for a project that never materialized. I have the clutch disc, pressure plate, master cylinder and slave cylinder as well as a flywheel for a two piece rear main seal chevy. Note that the clutch actuator is on the passenger side so it would be ideal for a yj or newer jeep with LH drop t-case also would be great for a tow vehicle. 850.00 obo cash only. If interested please respond with a pm and I will contact you or call 513-31seven-855two Thanks for looking.
v8-yj is offline   Reply With Quote
