Old 07-05-2013, 02:02 PM   #1
Tick be Gone
My engine developed a pretty good tick at the last outing....This is what I found.
Number four cylinder exhaust rocker arm.Checked the rest while the cover was off,found no broken ones.
Engine is tick free..
Old 07-05-2013, 02:14 PM   #2
I thought the only way to kill a tick was light it on fire
good find so all ready for its next beat down
Old 07-05-2013, 09:13 PM   #3
Thankfully,no fire needed on this Tick...
Old 07-05-2013, 11:05 PM   #4
That's a serious tick...
Old 07-06-2013, 01:37 PM   #5
What did the inside of the rocker look like and was the push rod ok ??
Old 07-06-2013, 03:18 PM   #6
It was indeed...Glad it was a simple fix and even better,cheap fix.
Looked liked some of it had been missing for awhile.The broken pieces you see in the pic I believe broke recently causing the tick.The very bottom part was not found.Push tube was okay.
Old 07-11-2013, 08:06 PM   #7
tjrider
So you ready for bigrock now? I think tom and robert are in
Old 07-12-2013, 07:30 AM   #8
Yep,looks like a local run will fit my work schedule.I'm in the process of replacing the stock ignition system just waiting on the last part (Accel cap&rotor)to show up.
BigRock will be a good test.
