Old 11-16-2013, 11:38 AM   #1
bootlegger
xj issue
My 98 sometimes just stalls out sometimes and will always restart.
I'm thinking crank sensor?
It sometimes won't start with the key, but someone has wired a toggle switch which hangs from the dash that will activate the solenoid and eventually the starter after maybe 10 tries.
There is a remote start on the vehicle and I'm wondering if it may be the cause.
Any thoughts?
bootlegger is offline   Reply With Quote
Old 11-16-2013, 03:53 PM   #2
Is this one issue, or two separate ones?
Old 11-16-2013, 03:54 PM   #3
bootlegger
Really not sure
Old 11-16-2013, 04:04 PM   #4
The toggle switch is suspicious. If there's a known bad connection in the ignition switch, that would definitely have the potential to shut off the engine, well, like you're turning off the key...
Old 11-16-2013, 04:37 PM   #5
bootlegger
Maybe it just needs an ignition.....
Makes sense. Probably why I can pull out the key while it's running.
Old 11-16-2013, 07:02 PM   #6
Ha! Yeah, that ain't normal...
