Old 05-18-2014, 12:23 PM   #1
Looking to buy
I'm looking to buy a Rzr Xp 900 here in the next month. I was going to get a XP 1000, but with all the goodies I wanted it was like 25k, so I'm going used with some goodies already on it.
I really don't that much about them so maybe you guys can tell me if they are worth it. What is too many miles or hours? Am I better off getting a low mile one and build it my self, or a higher mile one that has been built up already?
Out of these, which are the best deals.
#1 http://louisville.craigslist.org/sno/4433835015.html
#2 Gone
#3 http://cincinnati.craigslist.org/sno/4422038581.html
#4 http://lexington.craigslist.org/sno/4445588530.html
#5 Gone
#6 http://lexington.craigslist.org/sno/4454934158.html
Old 05-18-2014, 10:52 PM   #2
monkeystrong
Señor Monkey
monkeystrong's Avatar
I can't offer any info on which is a better deal, but I have been thinking about getting one also. I'd like to hear opinions on this too.
Old 05-19-2014, 10:18 AM   #3
ITLLFLI
I have a 2012 for sale with 300+ miles, roof with stereo and led lights, doors, harness', custom felt steering wheel and hub, bumpers, front and rear windows, cargo box, shoulder bag...etc
$14,000
Byron
513-470-848zero
ITLLFLI is offline   Reply With Quote
Old 05-19-2014, 11:22 AM   #4
Be careful where you buy one from. Being from Morehead, KY I can say that most folks there know how to use their stuff and use it often. If you buy one from Cincinnati...etc, it will most likely have been a toy rather than a workhorse.
I would shy away from a unit with modified stock components (chopped cages) and look at ones that have custom cages/bumpers with inspection. Doors, control arms and tires would also be on the desired upgrade list.
Old 05-19-2014, 12:14 PM   #5
fordman00
fordman00's Avatar
Me personally when I buy something used I want it with low miles and low hours.typically means it hasnt been rode hard and put up wet. But I know nothing about sxs.
Sent from my SCH-I535 using Tapatalk
Old 05-19-2014, 12:37 PM   #6
My low miles on my machines usually mean that they are finished! My old 800 is at the salvage yard now as the new owner finished it off a few weeks ago. The 900's are a great bang for the buck! Good luck with your searches.
Old 05-19-2014, 12:38 PM   #7
#2 or itlfli is my vote!
Old 05-19-2014, 12:41 PM   #8
Those were some HARD low miles. I suspect the 1000 is getting the same abuse...
Old 05-19-2014, 04:40 PM   #9
fordman00
fordman00's Avatar
Well obviously dont buy one from truggy.....lol
Old 05-19-2014, 08:33 PM   #10
kyrel69
Yes you do,,,,,, the parts form what ever he is saleing off
Old 05-19-2014, 10:10 PM   #11
If you buy a XP900 there are a couple must check things.
1 Make sure if its a 11 that it has the updated firewall heat shield.
2 Check the intake track from the inlets on the rear fenders down to and through the throttle bodies...look for the tell tale signs of being mudded. The air filter set-up on the XP's is super picky and it passes lots of dirt if it isn't perfectly assembled. I looked at two used 900's with dusted TB's before I bought the one I have now. The 900 is a great power plant but is notorious for having no tolerance for dirt of any kind.
3 Check the motor and trans mounts very closely.. on 11's especially , they are known for breaking clean off if wheeled even moderately in rocky terrain as the engine block hangs down very low between the frame rails.
4 Pay very close attention to reverse engagement and free play ..the 900 has a less than smooth tranny but the first thing that starts going bad is the puny reverse chain.
That's all I can think off the top of my head .
Edit....Get a power steering model...once you really start wheeling it and adding big tires and more power / performance parts you'll wish you had.
And get a cover for your truck... you wouldn't be driving it much once you get a SxS.
Old 05-20-2014, 04:49 PM   #12
solar1
10
Agreed. Low miles/hrs and but power steering model. I just put PS on my 800 S last week before a trip Tenn. Well worth it.
Old 05-21-2014, 08:19 AM   #13
CFD5
CFD5's Avatar
Another vote for itllfli's. I ride with him and it's not beat, mostly ridden on a local farm with no real big obstacles. Spends most of his time crawling at 5mph behind my jeep.
Old 05-21-2014, 02:31 PM   #14
If he still has it at the end of June I will check it out.
Old 05-21-2014, 04:44 PM   #15
Also pay particular attention when starting 11&12 models...they had a threaded idler shaft that's prone to coming loose and destroying the case . If you catch it early on you can save it but if not you're writing a $1,500 check.
Old 05-28-2014, 12:36 PM   #16
Here's one I thought was set up nice.
http://louisville.craigslist.org/sno/4466658177.html
Old 05-28-2014, 02:07 PM   #17
Already gone, sorry...
Old 05-28-2014, 05:52 PM   #18
Old 06-03-2014, 08:33 PM   #19
Thanks for all the help.
Jeff, you must have done some serious research before you bought one. I might have to get you to go with me before I buy one. Hopefully in the next few weeks I'll be ready to buy one.
Old 06-04-2014, 05:30 PM   #20
Let me know when and where and if it works for me I'll get with you..
Old 06-10-2014, 05:53 PM   #21
monkeystrong
Señor Monkey
I just bought a xp1000 2 seater. I have permanent grin!
Old 06-10-2014, 05:58 PM   #22
Sweet!!! I bet you do.
Old 06-11-2014, 02:50 PM   #23
Cool! That should fit nicely on the flatbed you talked about, won't even need a trailer...
Old 06-13-2014, 08:41 PM   #24
I'm ready to buy one now.
Must... resist... going 1/2 mile down the road and getting the 1000...
Old 06-13-2014, 08:51 PM
Old 06-13-2014, 09:05 PM   #25
monkeystrong
Señor Monkey
We changed our mind on it. Gonna wait a bit.
