Old 11-06-2007, 01:47 PM   #1
33TJ97
Hardcore Newbie
14 bolt drums stuck
I cant get the drums on my 14 bolt off. I tried using the adjuster screw but its stuck too. Is there another way to get the drums off or should I just cut them? I already tried beating them with a mini sledge. Maybe I need a bigger hammer? They will move about 1/2" Any help would be appreciated
33TJ97 is offline   Reply With Quote
Old 11-06-2007, 02:18 PM   #2
Sounds like the groove in the drum from the wear of the break shoes is probably holding you up a bit. If the adjuster can't be moved in or knocked off the shoes you may have to cut em. Sounds like fun!
Old 11-06-2007, 02:34 PM   #3
Talking
A bigger hammer or prybar would probably get er off.
Who cares how much ya damage em, cause you're converting to discs, right?
Or else this could be a good excuse for that plasma cutter you been needing...
Old 11-06-2007, 02:56 PM   #4
33TJ97
Hardcore Newbie
Yes, Im converting to discs. I just wanted to make sure I wasnt going to damage something important or have something unspring and hit me if I cut them. Thanks, looks like I'll be breaking out the grinder
Old 11-06-2007, 07:02 PM   #5
The grinder to cut em off? That will suck! Use some explosives or hook your tow rig up to the drum and rip it off. Make it exciting!
Old 11-06-2007, 09:11 PM   #6
hmmm, if you can't get the adjuster to move to back the shoes off, then see if you can dismount the wheel cylinder and let it fall into the drum. This may allow the shoes to fall into the center a little more, giving you room to get the drum off.
Good luck... and forget the grinder... get a sawzall or a portaband or something....
Old 11-07-2007, 12:47 PM   #7
Take a 3 pound hammer and beat them. You wont hurt the drums. They will pop off.
Old 11-08-2007, 02:27 PM   #8
33TJ97
Hardcore Newbie
I unhooked 2 springs and it still didnt budge. 7 grinding wheels later and its off! I dont have a better tool than a grinder for this job :( Thanks for all your help
Old 11-08-2007, 03:40 PM   #9
No explosives? Bummer! :(
Old 11-08-2007, 03:44 PM   #10
Stang849
Stinkin Bastige
Stang849's Avatar
Images: 236
Leave it to Truggy to want to blow everything up!!!
