09-16-2016, 11:07 AM | #1 |
- Moderator - |
Suspension Rebuild
I am beginning the suspension rebuild on my Jeep CJ-7.
Current setup is leaf in front and TJ Coil springs in back. Race Runner 14" shocks at corners. New setup Same 3 link hybrid in back. 4 link new setup with truss in front. ORI 16" shock/struts on the corners. http://www.cincyoffroad.com/gallery/...p?c=11&userid=
Keep them on all 4's Last edited by jeepmanjeff; 09-16-2016 at 11:34 AM. Reason: added gallery link |
09-16-2016, 11:46 AM | #2 |
- Moderator - |
I have to say our picture tools suck! Sorry I tried to flip some of the pics and it just does work. If your neck hurts my apologies
Keep them on all 4's |
09-19-2016, 12:56 AM | #3 |
- Moderator - |
Made steady progress this weekend. 4 linkis complete! I have 35.25" lower links and 25" upper. All triangulated to the max I can allow. No hinderance anywhere with full flex. Next up is hydro lines, brake Lines and exhaust relocate. Once the ORI get here I will be rocking again .
09-23-2016, 11:18 AM | #4 |
- Moderator - |
More progress. ORI shocks arrive today. Driveshafts installed and new center brake drop in. Will get new hydro lines tomorrow for steering and install shocks as well. This Sunday I pick up my 39.5 boggers I am trading my 44 for even Steven.
09-23-2016, 11:22 PM | #7 |
- Moderator - |
Wish but with work travel I am for sure not going to be done. This working on weekends is cramping my time frame.
10-04-2016, 11:28 AM | #11 |
- Moderator - |
Good...I have the front almost done and the rear will be done Friday/Saturday. James will be over Sunday to charge the shocks...then paint...
10-05-2016, 11:18 PM | #12 |
Señor Monkey
Nice work Jeff. It looks great!
10-06-2016, 07:50 PM | #14 |
- Moderator - |
Pics from the side as requested. I got the new radiator completed, left brake line ran, d-ring welded on for chains and struts turned to gain access for the charging ports.
10-08-2016, 03:59 PM | #16 |
- Moderator - |
More progress got the radiator bled and brakes. Made a new light bar for 40"LED light bar to be acquired later. Got a coat of paint on her as well. Lots of sanding off the old red that I hated!
10-10-2016, 11:50 PM | #17 |
- Moderator - |
Getting closer. I had to move the front axle strut mounts 2 times to
Get the clearance I needed for the tires. But it is done. Need to rerun the front brakes and paint again. Charge shocks as well then test. Sent from my iPhone using Tapatalk
11-10-2016, 10:49 AM | #23 |
- Moderator - |
Suspension performance
Well I have to say this was a great investment. Got a lot of complaints I was going to fast down the trails . The ride was fantastic and the flex was unbelievable. I did not lift a tire the entire weekend. Body roll was a bit scary at first but I got use to it. I am going to move the front shock completely to directly above the axle and where they attach at to the axle as well...so pretty much a redesign on the dana 60 but this will drastically help on the body roll and bring the height back down about 3 inches in the front and 2 in the rear I am estimating. I plan to start that after I get back from Haiti in 2 weeks.
https://www.facebook.com/photo.php?f...type=3&theater
