Old 11-03-2016, 04:58 PM   #1
Shock tuning
Does anyone know of a place that does shock tuning on SXS's? I know mine could ride better and also get rid of the bucking when you hit a ramp or whoops.
Old 11-07-2016, 08:56 AM   #2
Do your shocks have preload adjustment (threaded collars on the shock that basically tighten or loosen the springs)?
Old 11-07-2016, 03:42 PM   #3
Yes
Old 11-08-2016, 08:33 AM   #4
Probably worth playing around with the preload setting some as it may get rid of the bucking (assuming the back end is kicking up when hitting big bumps or jumps?).
I know there are several places that will revalve shocks and will try to find them. Think I have heard the cost is in the $600 range for this work.....and why I suggest messing with the preload first.
Old 11-08-2016, 11:51 AM   #5
I have messed with preload before. Never got it to stop bucking in the rear. I run the preload at the softest setting now so it rides good. I want it to ride like a 1000 does. Not sure if thats possible.
Old 11-08-2016, 02:11 PM   #6
This place is relatively local and can take care of your suspension issues.
http://www.clintoncountymotorsports....Ohio---4451621
