12-19-2016, 09:32 AM | #1 |
- Moderator - |
ORI Relocation
Started the front shock relocation.
Sent from my iPhone using Tapatalk Made some huge progress today. Got the front ORI and new engine cross brace completed. Sent from my iPhone using Tapatalk
Keep them on all 4's |
12-20-2016, 03:33 PM | #3 |
- Moderator - |
More progress today. All welds are done, air tank and PS reservoir mounts made. Now I have to paint!
12-21-2016, 11:14 AM | #6 |
- Moderator - |
Yep a lot of trial and error. Welding what I thought was the permanent location 3 times kinda sucked but I gained a lot of knowledge. Thank goodness I have a plasma cutter.
12-21-2016, 03:05 PM | #7 |
So the original locations were less than ideal (maybe I missed this in one of your other threads)
1976 CJ 5 1984 CJ 7 1993 K3500 GMC 6.5 TD |
12-21-2016, 03:55 PM | #8 |
- Moderator - |
This all started because I did not want to remove my shock hoops I have had for years because it entailed a whole lot of work. Not moving the shock hoops compromised compression and angles of the struts that caused severe body roll as well. So after my first run I did some searching for new shock towers and found Ruffstuff had a mandrel bent set for $120 that would make the relocation much simpler. The relocation ha only taken about 12 man hours to do. So I wish I would have done this from the get go. However I have learned a whole lot and the setup is spott on now.. At least on the lift.
01-04-2017, 03:55 PM | #11 |
- Moderator - |
