Old 11-19-2007, 06:02 PM   #1
Exclamation Carnage from Haspin 11/18
Here is the damage to the 3rd member, and right side axle is shot.
I can not get the birfields out...grrrrrrr
http://s188.photobucket.com/albums/z...t=IMG00200.flv
folders of pics
http://s188.photobucket.com/albums/z...damaged%203rd/
Looking for a right side axle and birfeild also!!
Old 11-19-2007, 07:01 PM   #2
Yeah they do look a bit loose! Weld them up and go!
Old 11-19-2007, 08:46 PM   #3
4RunnerAdam
4RunnerAdam's Avatar
Pinion bearing explode? Or did you break the pinion gear itself?
Old 11-20-2007, 07:46 AM   #4
kyrel69
I was looking at your pic. Did you try to pull the axle out with that bolt and chain?
Why did you not just pull the knuckle off and the axle would of come out the back side then?
Old 11-20-2007, 08:36 AM   #5
That makes it easy. Challenge yourself!
Old 11-20-2007, 08:01 PM   #6
well I tried everything to get it out, turns out that the someone put after market birfield rings on it so it would not slide out. so we had to take off the nuckle.
here is the damage
well the 3rd inside looked like this
it should have looked more like this
and the right axle
Old 11-20-2007, 08:09 PM   #7
Good break! If you are breaking it you best go big! Sounds more impressive when steel snaps! Looks like you will have it fixed soon! Come on down to slade (red river gorge) this weekend with the gang.
Old 11-20-2007, 08:12 PM   #8
bearing blew out and it chewed up the gears too inside the housing and blew out the birfield and axle shaft was chewed up too on the right side!
I need a right side axle for the front any one got one call me! asap! need to get up and going for this weekend!
and the right axle
