Old 06-17-2018, 06:54 PM   #1
Dana 35 Cross pin bolt
Just had to install a new ring and pinion along with a carrier in a Rear 35, I could NOT get the crosspin bolt to thread in all the way and was worried I was gonna snap it off.
I took and grinded the end of it down until I was able to screw it in all the way with lock tight. I ended up shaving at least a little over a 1/8...now I noticed that the pin is a hair short of going into the other side of the carrier..
Not a 35 expert.
Will the cross pin bolt break because it's too short ?
I goes all the way through the pin but a hair shy of the carrier.
Old 06-17-2018, 11:24 PM   #2
So originally, the little bolt only stuck through the crosspin and into the carrier by ~1/8"? That surprises me.
That crosspin really shouldn't see any endload at all, the bolt just holds it in place. Still, I think I'd rather clean up the hole in the carrier, to let a full-length pin seat like it should.
I may have a spare...
Old 06-17-2018, 11:28 PM   #3
If you have a spare that would be awesome if I could get that from you.
Let me know.
Old 06-18-2018, 11:22 AM   #4
Text sent...
