Old 08-22-2018, 06:43 PM   #1
Vehicle electrical grounding
I'm running some 0g cable from the battery on my Burb to the back, to run a small inverter inside, and eventually a small trailer winch.
It's got the stupid low-profile side lugs on the battery, so the positives all come off a separate distribution block, and the negative is grounded to (I think) the engine block.
Should I run a separate 0g ground cable all the way back up, as close to the battery as I can? Or just ground it to the rear of the frame, since the frame will have 10x the cross section that the cable does?
The shortcut will obviously be easier, but I've already bought the cable, so there's no extra expense at this point...
Old 08-23-2018, 04:45 PM   #2
On my rig, the 4/0 neg for the winch was grounded to the body. But it also has a 4/0 ground from the battery to the frame.
When i put the quick disconnect on my van for my inverter, i cut the plastic cover to the side connection on the battery a little so i could fit the end of the cables on behind. You can remove the little bolt on those and use a 3/8 bolt. I had to trim mine down some so it wouldn't bottom out. Way easier to tighten up than that 8mm head too.
Old 08-23-2018, 04:46 PM   #3
Further research, and talking to an electrician, says my theory is good: The frame itself is probably a better conductor than the 0g grounding cable.
The problem is, how is the frame grounded back to the battery? If the battery is jumped to the block, and the block to the body, and the body to the frame, how big are all those individual jumpers, and how good are all those connections?
To make it work, I would have to run a solid ground from the frame back to the battery, and at that point, it'll be easier just to run a cable the full length.
Old 08-23-2018, 04:49 PM   #4
Ha, just what I was saying...
I need to look at that. I don't have much room to work with, but I'd like something better like that.
Old 08-23-2018, 05:58 PM   #5
I use a 3/8" stud that is screwed into the battery terminal and then a nut to hold the cables on. That way you don't have to worry about the bolt being too long or too short. But of course this usually requires a little more clearance around the terminals and if yours is set up like my truck there is not a lot of room.
Regarding grounding the battery to the frame, i would think it would be easier to run the couple of feet between the battery and straight down to the frame versus running a cable all the way from the back up to the battery.
Old 08-24-2018, 10:16 AM   #6
you can also use a junction post to place all the grounds together for one nice easy setup. Here is where I bought my electrical items from. Great to work with and fast shipping
http://www.texasindustrialelectric.c...ion_blocks.asp
Old 08-28-2018, 06:27 PM   #7
You can remove the little bolt on those and use a 3/8 bolt...
You were right, and that's exactly what I did. I had to cut the rubber insulation off the factory cable end (like you did, but more) and then it all bolted up great.
Fuse holder on the battery itself, then ran both cables straight back together, along the framerail. Out between the body and the rear bumper, and velcro'd the plug in place. With the door shut, it's really well protected and almost invisible.
Thanks for the help guys!
ID:	9990   Click image for larger version
ID:	9991   Click image for larger version
ID:	9992   Click image for larger version
Old 08-29-2018, 08:49 PM   #8
Hot meals this weekend!
Old 08-29-2018, 10:00 PM   #9
Sweet!
Old 08-30-2018, 08:15 AM   #10
Originally Posted by wrenchmonkey View Post
hot meals this weekend!
nice!
