Old 01-07-2019, 09:59 AM   #1
Fuse box for ls swap.
Hi everyone. Let's hear what everyone has done or plans to do for fuse boxes for an ls swap.
Did you keep the stock fuse box from the engines wiring harness? If so how did you mount/ waterproof it?
If you wired in a new fuse box what did you use? Mouting/ waterproofing?
Thanks
Old 01-07-2019, 10:11 AM   #2
My dad would be the one to talk to. He bought a waterproof fuse box that works out great! I forget the name off the company that sells them.
Old 01-07-2019, 12:32 PM   #3
I believe this is the one I used, but I'd have to double check the MN when I get home.
https://www.waytekwire.com/item/4634...TMR-Mini-Fuse/
Old 01-07-2019, 01:00 PM   #4
I think I had 3 wires running to my OE fuse block for constant power, and 1 for switched power to the 40 amp relay that turned on the new fuse block. Not sure if you can split the power on these fuse blocks. Jeff used 2 blocks. one for constant, and 1 for switched.
Old 01-07-2019, 01:26 PM   #5
yep exact same blocks. has 5 mini relays and 10 fuses. relay has one post and fuses have another. I hooked up ground on the relay and 12v switched on one block and 12v constant on another. Everything in my rig runs thru a fuse on one of these boxes.
Old 01-07-2019, 06:33 PM   #6
You could also find a 12 circuit split buss and have constant and keyed voltage in 1 block.
