Old 01-21-2008, 08:20 PM   #1
bc35339
bc35339's Avatar
propane
I put propane on my yota. starts and runs but when I let off gas it dies.Any suggestions?
Old 01-21-2008, 09:27 PM   #2
JET455
JET455's Avatar
Don't let off the gas......;)
Old 01-21-2008, 09:31 PM   #3
hardluck
Poor Bastard
hardluck's Avatar
Heres your sign!
Old 01-21-2008, 10:14 PM   #4
tinbeater
tinbeater's Avatar
Did you try turning the idle adjustment up?
Old 01-22-2008, 09:48 AM   #5
jamie L
Check your idle, check timing, check your power to the cylinoid. Propane is equal to 110 octane, you can advance the timing, but not to much or you will overheat. For the hell of it, do you have propoane & is it turned on?
Old 01-22-2008, 09:49 AM   #6
jamie L
sorry about spelling
Old 01-22-2008, 10:38 PM   #7
bc35339
bc35339's Avatar
I took this propane off another truck that I sold. It ran good on that toyota. Iam not the one that put it on the truck I sold so I didnt really Know what I was doing and no instructions just marked everything and swaped so i did not think I would have to ajust the idle.This truck has a header and flow master so I guess that could change the flow? And I not sure if I have the cylinoid pluged in ther right spot It was pluged into the green connector that was connected to the carb which has 3 spots in it and cylinoid only has 1 so I might not have it connected in the right spot? yes have propane turned on and just had tank filled.
