Old 01-23-2008, 11:06 AM   #1
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Swap 92-95 4.0 in a 89 Cherokee
I have a friend with a 1989 cherokee with a bad 4.0. I have a good 4.0 out of a 92-95 YJ. Will this motor swap in easily to the Cherokee. The only problems I could think of is if the Renix Fuel injection intake and exhaust manifold bolt up to the block without any problems? Thought there might be some changes in that over the years.
Thanks
Josh
1994 YJ, 4.0, 5 speed.
Old 01-23-2008, 11:35 AM   #2
If you have both complete motors it should be a fairly easy swap. You may need to put the intake and a few other goodies from one on the other but no big deal.
Old 01-23-2008, 11:39 AM   #3
JeepHD
JeepHD's Avatar
92-95 block and head, everything else will be from the cherokee
Thanks
Old 01-23-2008, 12:29 PM   #4
TRy to get ahold of JFiscus. Jason has swapped an HO in to a Renix body, I think
Old 01-23-2008, 12:35 PM   #5
Here I is!
Everything you need to know should be in here:
http://www.terrainstompers.com/forum/viewtopic.php?t=14
The only things not covered are AX15/BA15 trannys - if you have a standard shift there are a few other steps/variations involved sometimes. What tranny ya using & what year is it?
If you want to call between 6-9pm weekdays I can answer some questions on the phone 513-967-7091 or PM me here.
Old 01-23-2008, 01:01 PM   #6
JeepHD
JeepHD's Avatar
Here I is!
Thanks, PM'd you.
Old 01-24-2008, 09:10 AM   #7
D3viLs0uL
D3viLs0uL's Avatar
Send a message via AIM to D3viLs0uL Send a message via MSN to D3viLs0uL
its an auto tranny...and is it really worth the swap i trust josh and all but its just a toy and DD in the winter.or just spend bout the same amount and get a used motor with 120k..thanks for the info guys..
_-97 cherokee 2dr 5sp 3" lift 1"motor lift 33" turdbirds-_
D3viLs0uL is offline   Reply With Quote
Old 01-24-2008, 01:18 PM   #8
The OBDI 4.0L HO is not much of a gain over the Renix 4.0L.
Whatever block is cheaper is the way I would go. It is really not much more complicated either way.
u-pull-n-pay Cincy had about 6 jeeps when I was there the other day if you need misc parts for the swap
