Old 03-04-2008, 11:28 PM   #1
Muddy 1
Will work for Jeep parts!
Problem with a 89 xj lift
I am doing a lift for a kid I know and we got the front done and have hit a bit of a snag. The bolts that attach the leafs to the frame are spinning. What is the best way to get these out?
Muddy 1 is offline   Reply With Quote
Old 03-05-2008, 12:10 AM   #2
cut them out with a sawzall or torch.
or heat them up and hammer them all day with a strong impact.
Old 03-05-2008, 12:52 AM   #3
remove the rear hanger and walk the spring up and down while using an impact or air wrench to spin the bolt with as little pressure as possible. once it starts to come out alittle you can get a pry bar behind it or a large boxed end wrench dropped behind the bolt head and a BFH .
These can be a real pain in the arse if I remember correctly. Isn't the nut inside of the uni-body ?
Old 03-05-2008, 10:15 AM   #4
Yeah Sarge it is hidden inside there. Basically cut a hole and get it out then weld a new one back in and cover your hole. its a ***** bud enjoy
Old 03-05-2008, 04:58 PM   #5
Muddy 1
Hey guys thanks for the help.
