Old 03-08-2008, 08:36 AM   #1
SixFtUnd
Danny Beach
SixFtUnd's Avatar
Help :)
should only one front axil spin at a time or should they both be spinning with it in 4 and off the ground
my drivers hub and u joind is bad but the other day my other tire worked fine
now that axil is not spinning
give me a call if you can
471-2617
Old 03-08-2008, 09:16 AM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
If the diff doesn't have a locker or limited slip, it is possible that only one tire will rotate while they are off the ground. If you stop the spinning tire the other tire should begin to turn.
Old 03-08-2008, 10:32 AM   #3
If its an open diff. they usually spin oppisite each other when off the ground,are both hubs locked in?
Old 03-08-2008, 10:51 AM   #4
SixFtUnd
Danny Beach
SixFtUnd's Avatar
left hub is bad they both are in the locked position though
Old 03-08-2008, 01:00 PM   #5
SixFtUnd
Danny Beach
SixFtUnd's Avatar
ok I stoped the left driveshaft and the right started turning
so I know whats up now thanks
Old 03-09-2008, 08:47 AM   #6
Oh,thats why they both weren't spinning then
