Old 03-24-2008, 03:23 PM   #1
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
AX-15 Rebuild?
How hard is it to pull apart an AX-15 for a rebuild, basically new synchros and if anything else looks worn? I have done the old T-150s and T-176s before, just not the newer ones. The tranny really shifts pretty good, just shifts hard when cold.
I have an NV3550 that I had put in in it's place and I ma just not happy with it. Sounds like a lot noise from the front bearing and it pops out of 3rd fairly easily, so I thought I would freshen the AX-15 up a bit and swap it back in.
1994 YJ, 4.0, 5 speed.
Old 03-24-2008, 06:19 PM   #2
4RunnerAdam
4RunnerAdam's Avatar
Here's a rebuild on the sister tranny, the R151
http://www.4x4wire.com/toyota/tech/r151f/
If it just shifts hard when cold, I'd try switching over to some synthetic oil like amsoil or redline. I've heard a lot of sucess stories about these oils. I need to change my R150 over too since it does shift hard when cold.
Old 03-25-2008, 12:53 PM   #3
If I had to rebuild one... I would do the NV3550... they seem to be quite a bit stronger, without the known weeknesses of the AX-15... but that's just me.
Gearbox is a gearbox... can't see how it could be dramatically different.
Old 03-25-2008, 01:21 PM   #4
JeepHD
JeepHD's Avatar
Yeah, I don't know why, but I liked shifting the ax-15 better. I know the 3550 is considered the better tranny.
Old 03-26-2008, 12:07 AM   #5
The down side to the 3550 is that the aftermarket has stopped producing parts and the only place to get them now is through the stealership , so the price is going to be way high.
