Gots me a problem. Here and there lug nuts with half of the wheel stud either break off or just end up missing. They do not seem to be too tight and not too loose. The stud breaks right where the nut threads into them. The rims are chrome plated eagle rims. Wondering if the rims are expanding and contracting with heat or if it is a torque issue. The truck is an 06 dodge CTD. Need to figure this out before I loose all of my studs. Missing 2 on one rear wheel and worried about towing 11,000lbs. Dealership (steelership) not too happy with all of the trucks mods and sceered to touch it. I am planning on replacing the studs on the rear wheel friday before the trip if the studs can be located. Anyone heard of this dilema?
Deja Vu... didn't you have this problem when you first got it... ??
Or is this the same problem?
I used to work at Beechmont Toyota and one of the service writers would bring in his Dodge Durango with broken rear wheel studs all the time. He told me "any good Dodge owner carries extra wheel studs with him at all times" and that Dodges are known to break wheel studs. I personally replaced 2 on 2 separate occasions. So, maybe its a Dodge thing?
I have owned 10+ dodge trucks in the past 6 years and this is the first time I have had a problem.
The contractor I work for has a fleet of the Dodge trucks of all years and sizes. I have been there 10 years and I have never heard of them popping lug nuts off. They do have to rebuilt the front ends all the time but no lug nuts.
#8 |
Stinkin Bastige
#9 |
Are you sure that they are the correct "shape" lugnuts for tha tparticular wheel?
I know that some wheels are very particular about how the lugnuts seat & center themselves in the holes. This is mostly on thicker wheels like aluminum though from my experience. |
#10 |
Not sure enough on that. I was supposed to get stainless hardware when I ordered the wheels and got chrome :mad: . I will check that out.
#11 |
i would measure the seat radius/angle of the lug and on the wheel. I would bet they don't match, and you are only making contact at a very minimal point with them, causing undue stress to them.
also, put your lugs on with a torque wrench, and i don't think it will happen again. broken studs (especially on newer vehicle) are often due to overtightening.
#12 |
ask Tinbeater, maybe he can ask some of the tech's at his work, he also works for a dodge dealer
#13 | |
#14 |
#15 |
#16 |
Planning on fixing these broken studs before I leave tonight on a 3 hour tour and torque them to 100 ft. lbs.. I will check on my insurance and medical coverage before I go though. :o
#18 |
I had AA before and ADD once too.
#19 |
#20 | |
I guess the sun rises and sets on your ass.......
#21 |
Been torqing em at 180 ft lbs :o
Got em at 120 now :) |
