Old 03-29-2008, 03:54 PM   #1
Help! My truck is trying to break!
Well this just happened today. When I put my truck into reverse it will no longer move on its own. When I give it gas it hops and makes lots of noise and as soon as I let off, it stops. The tranny pulls good and the rearend doesnt wine. Any guesses? I am thinking probably R&P. I will probably pull it apart on Monday morning to check it out
2000 F-250SD 2wd, Sterling rearend, I think e4od tranny, 192,000 miles, tranny always flushed when needed and an additive always added. Never got any metal.
Old 03-29-2008, 04:39 PM   #2
Jack it up and then try back up
Old 03-31-2008, 01:19 PM   #3
I'd really suspect the transmission...........if the rear end was that messed up there would issues going forward also.
Old 03-31-2008, 01:39 PM   #4
Sounds like trans. is giving up the ghost! I lost reverse and then after a couple hundred more miles lost first too and the fluid was still pink with no smell of being burnt.
Old 03-31-2008, 08:58 PM   #5
Aquaman
Same thing happened to me in my Suburban last year. Lost reverse.... Had to rebuild the tranny. :(
Aquaman is offline   Reply With Quote
Old 04-01-2008, 12:02 AM   #6
I thought that too but why would reverse go out before the forward gears?
Old 04-01-2008, 07:59 AM   #7
Just how the fluid travels. Sometimes 1st and reverse on certain trannies run off of the same bands, solenoids and so on as I have been told.
Old 04-01-2008, 12:15 PM   #8
It's not that uncommon.
Old 04-01-2008, 05:45 PM   #9
You know I hate you guys because I think you are right. A r&p would be so much easier. :(
