Old 09-01-2008, 02:49 PM   #1
jeeperjohn9095
Guest
Posts: n/a
SOA pro's and Con's
Greetings
Thinking about haveing a SOA on my 90 yj
Looking for input about the pro's and con's of doing this
and a shop who can do this for me
thanks all
Old 09-01-2008, 05:35 PM   #2
Fine with good strong springs, under 400 hp. and 40's. This is done all the time and is a simple swap with kits available. Armstrong automotive or Complete offroad for work.
Old 09-01-2008, 08:24 PM   #3
maddhatter
maddhatter's Avatar
I went with lift springs on mine and if I could do it over (and I will) I would have done a spoa on stock (more flexy) springs.
Old 09-02-2008, 11:12 AM   #4
Bear Chow
Bear Chow's Avatar
Let's face it a lift is a lift is a lift there is only one pro.
Pro's - more lift
Con's - axle wrap, could end up with to large a tire for axles, slip-yoke eliminater required, the extra $$ to make all the little things right.
if incorrectly done: bump steer, steering linkage binding, break line failure, death wobble, drive shaft come apart
if done correctly: $$ to do it right the first time.
