just a good ol boy
problems
i have a sammy and i put yota axles under it with 456 gears i got 6.1 gears in the transfer case and 33/12.50 boggers on it now im havin a problem with when i take it out i brake my transfer case mounts on the frame and have threw my rear drive shaft twice and i get it fixed and it breaks again so i dunno if it my buddys work that keeps failing or what maybe im just geared way to low and thats what is causeing it i was just wanting some outside input to how to fix my problems with it thanks for your input
Post pics of where the mounts keep breaking.
Sounds like possibly poor welding or else you need a beefier trans mount? Where are you at in Middletown? I could come take a look. |
With a stock samurai the t-case mounts are weak. I had 32's with 6.4 to 1 case and stock axles and gears and needed to rework the entire t-case cradle. Needs to be ridgid! They make bolt on kits to fix this and as long as you buy the good kits it will work. Mighty kong is the name of the kit I think. Look at how it is made and build it like I did.
truggy is right if its the stock mounts your breaking it is because they are way over stressed. many manufactures have t case buckets and the 3 mounts to choose from so my suggestion is get on izook and check out the links and get some parts or some good ideas
#8 |
Is this the sammy thats kinda back halved sitting at crack heads house? If so your pinion angle is too steep,so when the springs wrap up it binds the U-joint and breaks it.You'll need to cut the spring perches off the axle and rotate the pinion down. Are the steel arms of the T-case breaking,or just the rubber mounts between the arms and the frame?
#9 |
just a good ol boy
yea its the one. he never worked on it and then it started gettin messed with so i took it only thing he would say to do is move the rear end back and turn the case sideways somehow i dunno how he meant that. its breakin where the mounts bolt to the case
#10 |
any of you guys got a targa bar for a sami
that can be bought cheap?
#11 | |
I have one that spry painted OD green,haven't looked at it in awhile but I think its in pretty good shape. I'll look tonight and if its good $40,if its not so good less $s |
#12 |
Just about every Sami with low t-case gears I've seen that gets used on the trail has trashed the stock t-case mount. Sounds like you've already got somebody to look at it, but if you need more advice I can see what the other guys in our club have done.
#13 |
just a good ol boy
its over by sunset park not to far from u
#14 |
Can you drive it over here tomorrow night after 9:00 pm? I'll be in the garage after I get the kids to bed.
#15 |
just a good ol boy
i dont get off work til 1115 and it dont have lights on it but yea i probably would haha
#16 |
I'll be out there till midnight or 1 so come on by,The garage door will be shut so all the classy middletown folks can't see what I got,so walk around to the front of the garage and KNOCK LOUDLY so the dog doesn't think you're a crack head trying to rob me ,lol
#17 |
just a good ol boy
i work in lebanon so i wouldnt be in middletown til around 12 so it be around 1230 before i could get over there so if u out there and wanna mess with lookin at it that late give me a call my number is 513-465-7742 call around 1130ish so i no to come over or not
