Old 09-11-2008, 11:14 PM   #1
80-120 dc air switch
Where can I find a dc air pressure switch for 80 -120 psi. ? Making another onboard air setup. I need it to turn on and off the jeep compressor when it goes from roughly 80 to 120 psi. and it needs to be d.c. also. Last time I did this I found one on ebay but have had no luck recently. Trying to get this done before the W.V. trip! Thanks, Scott
Old 09-12-2008, 01:10 AM   #2
eighty3bronco
anywhere but there
eighty3bronco's Avatar
most air pressure switches are just a mechanical type relay and will run on any voltage. check mcmaster-carr. they should have what you need and you can get most things by the next day with ground shipping.
Old 09-12-2008, 06:44 AM   #3
Looked on their site first and found nothing that was DC. Also found nothing in my range of psi. either.
Old 09-12-2008, 09:14 AM   #4
JeepHD
www.buckeyejeepers.com
JeepHD's Avatar
Not the pressures you wanted but.
http://www.kilbyenterprises.com/psw1.htm
1994 YJ, 4.0, 5 speed.
Old 09-12-2008, 09:18 AM   #5
grainger is where i got mine
Old 09-12-2008, 09:22 AM   #6
Part # or any info?
Old 09-12-2008, 10:57 AM   #7
Part # or any info?
checking on the # would you like me to install also ill let know in a little bit
Old 09-12-2008, 11:23 AM   #8
How much do you charge? :( This job requires drilling and taping a round piece of 316 stainless steel with a 1/4 npt tap. Then you have to turn a wrench about 6 times and snap a plug on the end of the sensor. Should not take more than 5 minutes.
Old 09-12-2008, 11:53 AM   #9
4RunnerAdam
4RunnerAdam's Avatar
I have one of these Viar pressure switches that I'm going to use on my onboard air project when I get around to it. It seems to be a good part...nice heavy gauge wires, feels solid. Has a built in 12v relay.
http://www.4wheelparts.com/Towing-To..._pn=V%2fA90113
Old 09-12-2008, 01:06 PM   #10
Found the one I was looking for on 4x4 connection!!! Yaaaay
Old 09-12-2008, 05:44 PM   #11
eighty3bronco
anywhere but there
just because it says 120v does not mean that that is what it can run at. The switch is rated for that but at the same time can handle different voltages. We use alot of mechanical switches at work that say 120v but we are running 24vdc through it.
Old 09-12-2008, 06:41 PM   #12
Yeah I am running off of 4WheelParts actaully. I looked at Viair but I god a better deal at 4WP.com
Old 09-12-2008, 10:23 PM   #13
TomH
Gearhead
TomH's Avatar
I have the Viair 150-110 and it works perfectly.
